DONT USE 2.4ghz WIFI with a phantom 2
You can not use wifi for a video signal from a phantom 2.. you must use 5.8ghz tx
as when away from you, the signal from the camera will kill your signal from your tx/rtx controller.
your then in go home or if you rushed your takeoff.. you could be worse.. and when in go home mode.. the phantom will hit anything taller than 60ft.
Hope this helps some guys..
