DJI Release Inspire 1 Battery Heater & Battery Insulation St
The performance of your Inspire 1’s Intelligent Flight Battery is subject to environmental factors. Low temperature will have adverse effect on the performance of Inspire 1 Intelligent Flight Battery. The Inspire 1 Battery Heater helps to exert the optimum battery performance by heating the battery to a more suitable temperature (above 5 oC) before flight, enable the users flying their Inspire 1 in a more reliable way.
Specifications:
Recommended Usage Temperature: -20 oC to 5 oC
Heating Range: 30 oC±5 oC
Power: below 41.5W
Input Voltage: 18-26.1V, DC
Input Amperage: below 1.6A
Dimension: 62mm x 99mm x 115mm
Using the Battery Heater
Ensure the battery is fully charged and powered off. Insert the battery into the Battery Heater compartment.
Turn the battery on and allow it to warm for 10-15 minutes*. Do not leave the battery unattended for extended period of time.
Turn the battery off and leave it in the Battery Heater for an additional 5 minutes*. The Intelligent Flight Battery is now ready for use.
*Actual operation time is subject to environment temperature. Longer or shorter times maybe required.
Notice:
A 3-stage overheat protection mechanism has been incorporated into the Battery Heater’s design to prevent the battery from reaching temperatures that exceed its design parameters. To ensure that the battery does not overheat, the heater will be automatically deactivated at temperatures exceeding 30 oC, with additional failsafe barriers in place at 50 oC and 98 oC.
For more details, please visit https://store.dji.com/product/inspire-battery-heater
Inspire TB47&TB48 Battery Insulation Sticker
Apply the insulation sticker to the Intelligent Flight Battery when environmental temperatures are lower than 5˚C and remove the sticker when environmental temperatures exceed 5˚C.
Re: DJI Release Inspire 1 Battery Heater & Battery Insulatio
so it sucks power from your battery to heat it up a bit?? wonderful. if the weather is that cold I say carrying the battery in an inside pocket of your quilted jacket should see it get warm enough to be happy.
NOT a serious suggestion but shorting it out for a few seconds will put some heat into it.. :mrgreen: :mrgreen: :mrgreen:
Jerry P
