P4 Firmware DJI Refurbished P4 updates
What is the proper order to do updates?
Drone first then controller......or Vica versa ?
Thank you.
Thank you.
I learnt the hard way.
Update the RC first via the GO4 app.
Update the AC via Assistant 2.
Relink both if necessary, perform the new IMU calibration and leave the compass calibration alone unless prompted in a clean area.
Reactions: JohnnyD913
Thanks......tried that......but still can't link to the controller.
Just rec'd it this morning....spent hours trying to link.
Any help would be greatly appreciated..
The Spark linked very quickly before it flew away ☹️
Need a bit more info as to what appears on the app. If it says 'disconnected', tap on that and it should take you to a new window which should allow you to complete the update and hopefully be linked.
I have managed to update the Phantom4 and controller.
I was prompted to calibrate the IMU.....but after many attempts I am
Unable to get past page 4.
Any ideas, thanks.
Any ideas, thanks.
Not sure what device you are using, I had problems following the steps as I couldn't see the relative position of the drone on the background.
Try this:
IMU Calibration on P4P
Video on thread #2, the P4 is updated the same as the P4P
