DJI Phantom 4 Quadcopter Drone with upgrades - Excellent Condition
DJI Phantom 4 Quadcopter Drone with upgrades - Excellent Condition - SOLD!
Now $850 Includes:
Original Case (Shipped In original outer box)
Phantom 4 with only about 3 or 4 Flights
Phantom 4 Original Camera
Charger
DJI Intelligent Flight Battery
Original Phantom 4 Transmitter with optional HDMI module installed
4 x 9450S Quick Release Propellers for Phantom 4 Quadcopter
Camera Protection Guard
Brand new MaxxUAV ITELITE - DJI RANGE BOOSTER ITE-DBS02.2 with CleanInstall Option. *Still in Box (not installed)
Excellent Condition with only about 4 flights by experienced drone flyer.
Pictures are from the Internet.
Product Highlights:
Gimbal-Stabilized 4K / 12MP Camera
Visual Sensor for Obstacle Avoidance
Streamlined Shell / Magnesium Unibody
Top Speed of 44.7mph in Sport Mode
Maximum Control Range of 3.1 Miles
Visual Tracking of Moving Subject
Up to 32.8' Vision Positioning Altitude
TapFly - Fly With a Tap of the Finger
Avoids Obstacles When Returning Home
Up to 28 Minutes Flying Time
A sleek new design with magnesium unibody construction, obstacle avoidance sensor, dynamic range enhancing video modes, and a two-point-of-contact gimbal mount are just some the features DJI have introduced with the Phantom 4 Quadcopter. Thanks to improvements in efficiency as well as its intelligent power management system, the quadcopter boasts up to 28 minutes flying time. Its camera shoots DCI 4K (4096 x 2160) video at 24/25 fps and UHD 4K (3480 x 2160) at up to 30 fps. There is also a 120 fps mode in 1080p resolution for slow-motion effects. The camera will also take 12MP still photos in either DNG RAW or JPEG, with single shot, HDR, burst, and time-lapse modes to choose from.
Computerized flight control is nothing new, but the Phantom 4 is the first Phantom to be given a pair of eyes. Among other features, these front-facing visual sensors enable obstacle avoidance during automatic return home and allow it to track a subject. It also features Vision Position, a carryover from the Phantom 3 Professional and Advanced, which provides navigation for times when GPS is unavailable and the quadcopter is close to the ground.
One area where fixed-wing planes have traditionally held an advantage over multi-rotors is performance. The Phantom 4 aims to shake off this stigma. With its Sport Mode, the quadcopter can achieve a top speed of 44.7mph. That's enough speed to take to the races or follow fast-moving subjects, such as a vehicle or skier hurling down the slopes. Since you may need to slow down in a hurry, Active Braking brings to the quadcopter to a halt much faster than drag alone otherwise would.
Specifications:
Performance
Maximum Speed 65.6' per second / 20 m/s (Sport mode) Ascent: 19.7' per second / 6 m/s (Sport mode)
Descent: 13.1' per second / 4 m/s (Sport mode)
Maximum Altitude Above Sea Level: 19,685' / 6000 m Above Takeoff Point: 400' / 122 m (Software limit)
Hovering Accuracy Vertical: ±0.3' / 0.1 m (when Vision Positioning is active) or ±1.6' / 0.5 m
Horizontal: ±1' / 0.3 m (when Vision Positioning is active) or ±4.9' / 1.5 m
Flight Time 28 minutes (depending on conditions)
Flight Control System
GPS Mode GPS / GLONASS
Vision Positioning Velocity Range: ≤ 32.8' per second / 10 m/s (6.6' / 2 m above the ground)
Altitude Range: 0 to 32.8' / 0 to 10 m
Operating Range: 0 to 32.8' / 0 to 10 m
Operating Environment: Surface with clear pattern and adequate lighting (> 15 lux)
Obstacle Sensory Range 2 to 49' / 0.7 to 15 m
Transmitter
Frequency 2.400 to 2.483 GHz
Communication Distance Up to 3.1 miles / 5 km (outdoors and unobstructed)
Transmitter Power 23 dBm
Operating Current 7.4 VDC at 1.2 A
Battery 6000 mAh lithium-ion polymer (LiPo) 2S
Operating Temperature 32 to 104°F / 0 to 40°C
Camera
Sensor 1/2.3" 12 MP CMOS
Lens FOV: 94°
Focal Length: 20 mm (35 mm equivalent)
Aperture: f/2.8
Photo Resolution Up to 12 MP (4000 x 3000)
ISO Range Video: 100 to 3200
Photo: 100 to 1600
Electronic Shutter Speed 8 to 1/8000 second
Video Resolutions DCI 4K (4096 x 2160): 24p, 25p
UHD 4K (3840 x 2160): 24p, 25p, 30p
2.7K (2704 x 1520): 24p, 25p, 30p
1080p (1920 x 1080): 24p, 25p, 30p, 48p, 50p, 60p, 120p
720p (1280 x 720): 24p, 25p, 30p, 48p, 50p, 60p
Photo Modes Single Shot
Burst Shooting: 3/5/7 shots
Auto Exposure Bracketing (AEB): 3/5
Bracketed Frames at 0.7 EV Bias
Time-lapse, HDR
File Formats Video: MPEG-4 AVC/H.264 in MOV wrapper (up to 60 Mbps)
Photo: JPEG, DNG RAW
Recording Media Type: microSDHC/SDXC card up to 64 GB
Format: FAT32 / exFAT
Note: Class 10, UHS-1 or faster card required (64 GB maximum size)
Gimbal
Control Range -90° to +30°
Flight Battery
Chemistry Lithium-ion polymer (LiPo)
Capacity 5350 mAh, 81.3 Wh
Configuration 4S
Voltage 15.2 VDC
Weight 16.3 oz / 462 g
Maximum Charging Power 100 W
Operating Temperature 14 to 104°F / -10 to 40°C
Charger Voltage: 17.4 VDC
100 W
General
Dimensions Not specified by manufacturer
Weight With battery: 3 lb / 1.4 kg
I just don't fly it as much as my Inspire, and with the new releases coming out I thought I probably should sell it now before the market is completely flooded.
Fimaj
