DJI goggles question?
  • Thread starter Deleted member 68677
  • Start date
Goggles at 100%.. and plugged into the wall.. after 3 hours of gaming using the goggles on the PC, the battery life has dropped down to 70%...
Reactions: Capo
i can’t believe you wore those uncomfortable things for 3 hours lol.
They are really not that bad.. My neck is not bothering me. It's been about an hour since I removed the goggles and I feel fine. Goggles work great, picture quality awesome, No pixelation, No lag, No disconnection, worked very well for me.. I will say this. There is one hell of a learning curve to getting these goggles to work right,with all functions and features working correctly. There is a lot of misinformation from retailers, distributors, and sellers. And let us not forget DJI customer support. Other than that, they work fantastic for me... Tested on P4 and P4 pro. No Problems...
Reactions: ChipperRay
70% after three hours? It sounds like there is some charging going on, but not enough to keep up during use. I suspect that heat generated during use may be limiting the charge rate. Battery charge systems usually limit charge rate based on temperature.
tpren3
