- Joined
- Mar 29, 2016
- Messages
- 180
- Reaction score
- 57
- Age
- 59
- Location
- southern california
- Website
- www.zanderlanephotography.com
...hi jogforfitness; I can't make out the text, can you post a higher resolution photo?
I just finished a run about 3 miles out and back, using Tap2Fly. It was a pretty good flight, but one time when I was tilting the gimbal, my Mini 4's screen went to black and white for a second. It didn't do it again for the rest of the flight. It could very well be the Mini and not Go 3.0. FYI, it is currently 75 degrees F here so I don't think I had any overheating problems....sigh; the firmware dance continues - good luck and please let us know how it behaves!
Naw, it was gimbal tilt. So far, yawing hasn't given me any problems so far....hmmm, you're sure it was when you were tilting and not panning? - I only ask because when I go out a ways and start panning the bird left or right, that will sometimes cause signal drop out, I think due to the whole bird turning and thus reorienting the antennas and their coverage patterns - was the drop out way out near three miles or closer to home?
I'm using the IPad Mini 2 on DJI Go app version 3.0.0 and I cannot for the life of me find how to change the video size or other video options anymore. The old MENU button is no longer there and the settings icon doesn't give me any of those options either. Anybody having the same issue?
Can't anymore adjust camera tilt in flight (C2+ wheel). Note I have tested this while not flying as worked before in this context
Geo off not found..Here is a screen shot of my 3.0 version (for IOS) of DJI settings with the P4 on.
I did....Connect to your phantom. After your RC and bird are ON, then look at settings.
Sorry I left that out. Yes, it was 3.0. My battery is about halfway full right now so I should be up and flying again in about 30 minutes or so. I'm really hoping I don't have a repeat of yesterday or any other surprises.
Also, I've posted her that when it is in the high 90's and above and my iPad Mini 4's screen brightness is turned to max, the last few minutes of the flight are almost unwatchable due to it overheating. I'm pretty sure the effects I saw in my post above were not related to the Mini overheating since it happened at about 5 minutes into the flight and it was in the mid 70s.
Hope all's better now. Will wait for your update.
