DJI GO and Litchi can coexist on a Samsung Tab A
I use both DJI GO and Litchi both loaded on my Tab A at the same time. as a matter of fact if you follow these instructions you can choose which one you want to use every time you fly.
First go to your setting page,
Under applications under default application selsction choose "ask ever time"
Be sure to clear the default setting for your done. This is important.
Now, if you follow three instructions it will work every time.
Be sure your tablet is off and neither app is running.
First turn on your Phantom
Next turn on your remote
Once there connected together and only then, turn on yourTab A.
After it boots up give it about 30-45 seconds and your tab will ask you for your default selection
Between the 2 apps, Choose the app you want to use and choose "just once."
If you close you app before shy down it will ask Agian next time.
If you have a default app set, use the same process and will bring it up and open it automatically.
[emoji41]
Yup.
In fact, this works on any Android device. The only problem occurs when both are running at the same time. Because Android is a full multitasking OS even when an app is in the background it can still have components that run and can contend for resources -- particularly if they were poorly written for the Android run-time model. Especially failing to fully understand what services are and how Intents (Android programming stuff) work... It's a very elegant and efficient model, but also radically different than iOS, where primary development for DJI GO [4] is done, and then ported to Android (apparently).
rockymountaincaptures
