DJI GO 4.0 is out for iOS
So, I fly a P4. I also have a lot of flight logs on the v3.x app. If I install Go v4.0 will it sync with my previous logs from v3.x?
H264 goes up to 4k @ 60fps
K265 goes up to 4k @ 30fps
The lower the framerate at a given resolution the higher the final image quality should (in theory) be as less data per second is being crammed into the 100MB/s limit. H265 takes too long to encode to manage 60fps on the encoding hardware in the P4P. To post H265 effectively it needs to be converted to something like ProRes or DNxHD.
If I wanted to extract images from my P4P, would the stills be better quality using H.264 at 30fps, or the new H.265 at 30fps?
Reactions: GadgetGuy
Does anyone face the same appearance after the last update of the DJI Go 4 app? No correct messages being displayed, on variables?
Solved: switch to English instead of German
