DJI Assistant 2
I am having trouble with saving the settings using assistant 2. how do you do it? I have N3 and connected to Taranis x9d/x8r via sbus. I can sett everything up like I want it to be and then I shut down the software, disconnect to the computer, disconnect the battery, and turn off my Taranis. when I setup to run without propellers to make sure it works properly, I cannot get the motors to startup. they used to startup but now they don't. not sure what happened there. so when I go back into assistant 2, I have to set just about everything up again. the sbus connect doesn't seem to work. I end up having to calibrate the sbus setting again, plus all of my switches have to be reset. what am I doing wrong?? just for info, I have this on f450 with e310 motors and esc.
Reactions: Africamedic
