DJ6 and Phantom 2.4G RFv3 not linking.
Hi all...
I bought a DIY drone from a guy a while back. It was operational.
  • It has a NAZA-M V2 controller
  • DJ6 Remote
  • Phantom 2.4G RFV3 receiver.
I flew it into a tree and had to make some repairs. Since then I have not been able to get the radio and receiver to talk again. I have checked and double checked the connections for the NAZA controller. They are all hooked up properly.
If I run DJI NAZAM Assistant 2.4 a couple things happen.
First I see a message box telling me the following
"Configuration error, this may cause by firmware upgrade from old version or abnormal Tx calibration. Re-calibrate your transmitter and power cycle your controller and check all of the parameters."
If I go into Basic, Aircraft I can test and run a "Motor Test" on each propeller and each will spin.
When I have the MC disconnected from the computer, the LED will blink red, when I plug it in to the computer it's solid green.
In the NAZA software, the small little LED lights in the bottom left corner, the green one is lit, the blue one will blink for a while then stops.
Any help will be greatly appreciated. Thanks
Rick
