Difference between P2V and P2V+
the p2v+ is newer and has a better camera
All the transceivers/transmitter are stronger on the plus. So the range is longer. The gimbal is significantly more advanced. I think the ESCs, motors, and props have minor differences. The original Vision has the FPV transceiver in the camera, but DJI moved the transceiver into the body of the aircraft on the plus. The original Vision gimbal is controlled with your finger on the screen of the mobile device.The plus has a physical gimbal control on the corner of the controller, The original Vision's controller runs on AA batteries. The plus controller has a Lipo.
@Clint B you seem very confused, a quad whether it's the p2v or the p4 is controlled by the transmitter
FPV is first person view, the quad can relay the image the camera sees onto a phone or tablet so you can see what the camera is seeing. You can use FPV goggles if that is what you mean instead of a tablet but you still need to move the quad around using the transmitter
