I have accidently set my default app to the DJI GO4, and can't figure out how to take it out of default so I can use my Litchi app . When I turn my controller on it used to ask what app I wanted to use, then it would ask if I wanted to make that app my default, I usually hit no, but must have hit yes by mistake.Any help would be appreciated. Just stumbled across the answer, just incase anyone else needs the info :
- If you have another app (such as DJI Go) set as the default for the remote controller USB connection, you will need to clear the defaults for that app in your mobile device (Settings - Apps - DJI Go (or other app name) - Clear Defaults). Some devices automatically set the app you start as default, so this step may have to be done every time you want to switch app (for example from DJI Go to Litchi and vice versa)
