Decrypt any DJI flight log with Flight Reader
A new version of Flight Reader is available. Release 1.7.9 includes the following changes:
  • Resolved an issue that prevented photo and video data from being extracted from Mini 2 flight logs.
  • When opening the map view for a processed flight log, the map will use the current “Log viewer map size” setting from the “General” section of the Flight Reader Options window instead of the size that was selected when the flight log was processed.
See the release notes for a complete list of changes.
A new version of Flight Reader is available. Release 1.7.12 includes the following changes:
  • Added a new OSD.tiltInclination field to display the drone’s overall tilt angle, showing how much it leans relative to a level horizon during flight.
  • Add new fields DETAILS.droneManufacturer, DETAILS.droneModel, and DETAILS.droneManufacturerModel allowing the drone’s manufacturer and model names to be shown separately or combined.
  • C1 and C2 button presses from all DJI RC remote controllers are now captured in the RC.custom1Depressed and RC.custom2Depressed fields.
  • Resolved an issue introduced in Flight Reader version 1.7.9 where the CAMERA.isVideo field could incorrectly remain set to True after video recording stopped.
A new version of Flight Reader is available. Release 1.7.15 includes the following changes:
  • Added a new DETAILS.sha256Hash field. This SHA-256 hash uniquely identifies each flight log file based on its content.
  • Added support for syncing TXT flight logs from Android devices using Litchi Pilot.
  • The Mavic 3 Multispectral model name now correctly displays as “Mavic 3 Multispectral” instead of “Mavic 3”.
A new version of Flight Reader is available. Release 1.7.18 includes the following changes:
  • Added support for syncing TXT flight logs from DJI RC remote controllers or Android devices using Dronelink.
A new version of Flight Reader is available. Release 1.7.21 includes the following changes:
  • Added new fields RTK.aircraftGeoidHeight [ft] and RTK.aircraftGeoidHeight [m] to display the geoid height offset at the aircraft’s location based on the EGM2008-1 geoid model.
  • Renamed RTK.aircraftAltitude to RTK.aircraftEllipsoidalHeight to better reflect its meaning.
  • Updated RTK.aircraftAltitude to show the calculated ASL altitude value using the EGM2008-1 geoid model.
  • Fixed a crash that could occur when right-clicking a column in any generated log and selecting Hide Column.
A new version of Flight Reader is available. Release 1.7.23 includes the following changes:
  • Added a Byte Order Mark (BOM) to CSV files to ensure they open as UTF-8, allowing foreign characters to display correctly in applications like Excel.
  • Resolved an issue that sometimes prevented flight logs from downloading when syncing from a DJI account.
A new version of Flight Reader is available. Release 1.7.24 includes the following changes:
  • Added support for processing Mavic 4 Pro flight logs.
A new version of Flight Reader is available. Release 1.7.26 includes the following changes:
  • Added the option to display the OSD.flyTime field in charts, allowing you to view the current flight time in minutes and seconds.
  • The flight map snapshot now uses OpenStreetMap as the default map source. To use Google Maps instead, you can enter your Google API key in the API Keys section of the Flight Reader Options window.
  • Resolved an issue where the After processing log file action (configured in the General section of the Flight Reader Options window) was not triggered when importing a flight log via FileImport Flight Log in the main Flight Reader window.
  • Resolved an issue that caused the Google Map to fail to load in the map window.
pickwicknick
