Deactivation of firmware upgrade warning
Discussion in 'Standard' started by julien92, Sep 16, 2016.
  1. julien92
    France
    Hi there,
    I own a P3S.
    I was wondering if there is a way to deactivate firmware upgrade warning into DJI GO.
    For example : if I'm in 1.5.7 firmware, as 1.6.8 is available, DJI will warn me about it :
    - into the splash screen of DJI GO (OK, no problem about it)
    - but ALSO during the flight, with a big red warning at the middle top of the screen, which is really annoying
    Assuming I don't want to upgrade to the latest firmware, how can I deactivate this upgrade warning?
    Many thanks in advance! :)
    Julien
  2. RodPad
    Pacific,NorthWet, 97031
    Don't think so, I would if knew how. I only get that warning when the unit is warming up, once is safe to fly I don't at least I don't remember. :rolleyes:.
    Maybe if loose signal while flying?
    Rod
  3. apollo64
    I get it when booting up but dont remember seeing it when flying, i would rather not do update as happy with it as is
  4. RodPad
    Thanks for your reply, but this concerns me.
    "device locked FW required"
    Which is the most reliable firmware release
    Rod
  5. apollo64
    The way i see it a firmware update is optional, if the quad is working fine on a firmware set up why change it
  6. RodPad
    @ShivarenoP3 said,
    "HOWEVER, I got the "device locked FW required" message when I attempted to auto take off and manually take off."
    I thought he couldn't take off Auto or Manually. (Device Locked). Hopefully he will give us a yes or no.
    Have you ever seen Device Locked?
    Rod
  7. tcope
    Salt Lake City, UT
    That is certainly an option. However, I'll mention this as I've done before.... everyone thinks their Phantom is working just fine.... until something goes wrong. Firmware updates may add things that help and that you don't see until something is wrong. For example, when the battery is 25C you now see a warning. When it's a little lower you see a warning that the proposition is set lower as the battery is cold. If you don't have this firmware you never know if this issue... until something goes wrong.
    Just something I'm mentioning.
  8. apollo64
    No, i have not had the "device locked", you have me thinking i should do a FW update, but with my luck it would go wrong and i would end up with a useless quad
  9. RodPad
    Not me, I am at 1.5.7, 1.6.8 came out about two days before the shipped it back, never again.
    Rod
    apollo64 likes this.
  10. apollo64
    so your sticking to 1.5.7 pretty sure thats the one i am on
Similar Threads - Deactivation firmware upgrade Forum Date
rc light blinking red and quickly after firmware update on drone Phantom 4 Help Yesterday at 5:07 PM
Professional Image Transmission/Firmware Updates Phantom 3 Help Monday at 1:58 PM
P4P firmware to 01.05.0300 Video Photo Problem Phantom 4 Pro Help Sunday at 6:54 PM
P4P firmware to 01.05.0300 Video Problems Phantom 4 Pro Help Sunday at 5:11 PM
Is true after upgrading new firmware? Phantom 4 Pro Help Sunday at 9:02 AM
