Crashed Phantom 3 standard
We crashed our new Phantom 3 standard. The only damage seems to be with the camera gimbal mount and connection wires. We have located a replacement mounting bracket, but we are not sure what type of wire to search for. The wire that was damaged was a single grey wire running from the drone body to the camera. The wire pulled apart from the connector that attaches it to the camera. Can anyone identify the wire in question? Can it be repaired, or does it need replaced? Any help would great.
Just completed the same repair. You need DJI part 97 2.4Ghz antenna. I broke the black one but they are sold as a set for $18 at Multicopter Wharehouse. Decided while apart to paint.
Reactions: microraptor
Thanks for the information. Was it difficult to disassemble and locate the part? By the way, color looks great!
Disassembly isn't bad. Just take your time and label screws. I had to remove my main board, motors, and LED lights to replace wifi cable (wide plug of 6 or so gray wires on camera). Your antennas will be right beside your battery tray.
brianklenhart
