convert flight logs
I found this to be tedious doing all that in order to get my overlay. I said screw it and just now record with litchi when I want the data to be present. In fact litchi will let you record audio as well. So I can make comments on the flight as well as have data showing. This was easiest so I don't bother with converting things anymore.
@Tony Cowan you're right, converting logs is a pretty arduous process where you have to go in and out of multiple different systems.
I'm part of a team building out software to analyze flight logs from DJI GO, Maps Made Easy, and other applications, so that you can view the logs in the easiest way possible. We're also integrating other features like weather and airspace laws to give a more comprehensive picture of what your flight looked like.
If anyone is interested you can check it out here: trydash.nvdrones.com
jack klausner
