Controller Cracked Threaded Holes!!!
One of our local guys had the right stick fall completely inside the controller and lock the phantom in full speed forward flight. He managed to yaw it around and do circles while attempting to get the stick back out again. Eventually it worked loose and he was able to get the aircraft back under control. Turns out all of the threads holding the stick in place had stripped and the stick dropped into the controller body. Scary stuff!
wow that is scary, hopefully they fixed this issue on the p4, the plastic does look a little different.
Wow that is scary! DJI definitely has problems with their plastic. How about this for scary?
Just get a hot glue gun from a hobby store. Put a few blobs around the edges and hold the case together until it cools. You will still be able to open it if you have to with some pressure and a butter knife. The excess is easy to remove so cosmetics are not a problem. Fixed a million remotes and radios this way
C'mon.... Told you a million times not to exaggerate, Dave....
