Hello
Dirk invited me!
Ok if you broke it here I can help
First the white connector is
Molex #51021-0200 ( 2 position )
This part might be ok?
Secondly:
The crimp pins inside are
Molex #50079-8000 ( terminal connectors )
They require a special crimping tool, about $20. ( engineer PA-09 ) eBay!
I have plenty of these parts, and would be glad to supply you with them, but they are TINY and very hard to get right!
Option 2
Send me your battery with broken leads, and I can fix it for you, up to you? You'd have to cover shipping, but I'll do the repair for free! Let me know!
If you want to tackle it:
I use
( DIGI-KEY )
1) 51021-0200 ( 2 position ) X1
2) 50079-8000 ( terminal connector ) x10 ( buy multiples, they are small, and easy to damage ) few pennies each!
Tool
eBay ( $20+ )
( engineer PA-09 )
The little pins are kinda hard to do, first cut wire so lengths are EQUAL, next, strip wires back 1/16" back,
Place terminal into pliers, then slide wire in, first crimp INNER CRIMP, crimp to wire, NEXT, crimp outer crimp, crimp to insulation, once both done, slide the pins ( tooth up ) into plug end ( make sure polarity correct ) that's it, plug the battery into Tx, go have fun!
Let me know, I'm in Florida!
Jerry
J Dot
Wanted to add:
If you want to try your luck, I'd be happy to make a short instructional video for you on how to do it correctly! Let me know!
