Controller antennae
Hi there guys. This is my first post here. Recently I dropped my controller for my phantom 3 standard, and the white antennae snapped. The inner cable is still intact, but the white tube is getting ready to fall off. Does anybody know where i can find a replacement antennae? I will attach an image of the part in question
Good deed Tim . I have one also and also the antenna pads from inside the TX and the bird if anyone else is in need .
I broke the connector off of the wire connecting my external antenna to the circuit board. I see that I can replace the cable with
Phantom 3 - Receiver Antenna 5.8G (Sta)
but I am not sure how the antenna wire fits in the plastic antenna housing.
Well if you remove the old antenna then just reverse the process .
The antenna and wire are 1 .You will have to replace the whole thing .
Welcome to the forum Mike.
Looks like I ordered the wrong cable. How do I get a replacement antenna for the controller on my P3S?
Reactions: Santiego
i have the same problem but it only comes off when i try to move it up or down. i just keep it in the upright position and have no problem
Usachman
