Considering Litchi to Deal with DJI Waypoint/Tap Fly Limitations
Fountain Hills, AZ
Hi All,
I am considering purchasing the Litchi application as a substitute application to deal with DJI waypoint/tapfly limitations associated with DJI GS Pro and DJI Go applications. What limitations am I speaking of:
  1. DJI Go Tapfly. Tapfly has a minimum speed of 2.2 MPH. With the free rotation method I can point the aircraft in any direction for filming.
  2. DJI Go Way Point. Waypoint has a minimum speed of 0.1 MPH. However, camera must be pointed in a direction along the flight path.
  3. DJI Groundstation Waypoint. Minimum speed is 4.5 MPH. However, I can change the direction of aircraft for filming.
Ideally, what I am attempting to do is fly a very simple mission waypoint mission at about 0.3 MPH and point the camera 90 degrees to the flight path. As far as I can tell, none of DJI applications allow me to do this. Can I do this with Litchi?
Thank you in advance for you help.
Donald Barar
You can definitely do this in Litchi. You might also want to try course lock in DJI Go 4 first. Set heading then lock course then yaw to desired angle.
You cannot. Have to do that part manually. Sounds like Litchi is going to be best bet for your application. It's very easy to set up and fly waypoint mission
You can even easily have the drone focus on a point of interest throughout the entire mission if needed.
What I am attempting to do is shoot a hyperlapse with the drone flying perpendicular the direction I am taking images. Not certain how a focus point would work in this example as the aircraft would be moving circularly around the focus point.
If flying from point A to B in a straight line (or curved for that matter), in Litchi, you can fly toward B while having drone camera point in any direction you want OR you can have it fly from point A to B in a straight line while automatically focusing on an assigned "Point of Interest," or focal point--automatically yawning drone as it flies by. Depends on the look you want and what you want the camera to focus/point. POI is different in Litchi. What DJI GO calls "POI," Litchi correctly calls "Orbit." Hope this helps.
Jeeperke
