Need a bit more info, are you saying that the phantom will only rotate in one direction? If so then you may need to check the calibration of your remote controller.Trancoz said:After a advance calibration compass, I get a sucefully standard calibration compass. I did that a few times but still rotate in ine direction. Any recommendation to do?
Thks madwalk. It's rotate in one direction I'll try correct the rc.Madwak said:Need a bit more info, are you saying that the phantom will only rotate in one direction? If so then you may need to check the calibration of your remote controller.Trancoz said:After a advance calibration compass, I get a sucefully standard calibration compass. I did that a few times but still rotate in ine direction. Any recommendation to do?
