Clear Tape on Camera Assembly of P3S
Chicago, IL
Looking carefully at my P3S, I noticed there was some clear tape covering 2 of the 4 screws holding the camera assembly to the underside of the AC. The tape is clear, size about 50mm × 16mm, and one of the ends is orange/yellow. I was tempted to remove the tape but then thought it might be there to indicate if the bird has been opened or tampered with. Kinda like those shiny/silver tapes you see on some electronics, and if you peel them off, the silver pattern breaks into small squares.
Any thoughts?
It's okay to remove it. It's just like the protective tape you removed from the various other areas of your Phantom/RC.
akinproplumbing
