Clean Phantom 3 standered dbs mod
Is there a way to install the dbs mod without drilling I want to get betters ranges and dbs seems to be the way to go but I don't want to drill any holes. Solutions?
Welcome to the forum Patrick and yes some just get longer cables and remove the antenna then run them through the hole . There are several threads on it and will see if I can find one for you if you can't .
Here ya go..Help with DBS with no drilling
Reactions: Patrick.g
Your very welcome and you will like the panel, I have 3 on .
The mavic don't need it or it would have one .
Good luck with your install and just take your time and if
you run into any problems just ask as there's many on here
that can help .:)
My only problem is finding the longer cables I can search just what are they called and thank you in advance
Cleanest way is installing the ARGTek mount and connecting the DBS wires to that. Zero drilling involved and 'almost' looks factory fitted.
Don carlos
