Check your props before every flight!
I flew my pro for around 30 minutes this morning, 4 different flights on 2 different batteries. After my last flight as I was packing up, I started to take off one of the props and it was slightly loose. Could have been a catastrophe if I flew for much longer.
I learned that after every flight, I will check the prop tightness.
@Rideswings thanks for sharing. So often doing the little things (or forgetting to do them) make a big difference.
You probably didn't install it properly before the first flight.
I made sure I did tighten them on the first flight, which is the reason for this post. They came loose somewhere after my preflight and when I was packing it up after the 4th flight. Im going to be checking them after every flight from now on.
Crashed from a prop coming loose after preflight?
Yep, checked them all & after flying around for a little over three min. , I watched a Prop fly off & disappear , Drone flipped end over end & fell about twenty five feet into an over grown field , Broke the Gimbal & Camera off .
