Changing the Phantoms Internal Radio Frequancy
England, Nottingmamshire
I could do with some help please, on the FC40, I can see the 5Ghz Receiver and it has two plugs on it. My 2.4 Receiver with remote arrived and the Receiver only has place for one of the cables. What do I do? I will attach some photos
Original 5G in Quad: http://prntscr.com/41khqg
New 2.4 receiver: http://prntscr.com/41khx5
Plug the cable coming from the X2 port on the NAZA to the pins on your new receiver. The cable in the X1 port is used for gimbal tilt control and the receiver you bought doesn't have a separate channel for that...it looks like the receiver from earlier models of the P1 rather than the receiver that's in the P1.1.1 and the standard P2 (which have both connections).
Will check in the morning -- Morning: I have plugged the cable from the X2 port into the receiver in both orientations and the Phantoms LED indicator just flashes Orange rapidly. I can assume that the controller is connected to the receiver becasause when I turn on the transmitter the red light on the receiver disappears!?!? is there anything I need to look at in the Naza software?
All done, had to change the receiver type in the Naza software, thanks for the help!
