Carnage
Hit a small limb about 10 foot off the ground and the gimbal mount broke causing the camera ribbon to be pulled out of the connector. Any ideas on where I can get parts and a wiring diagram or is this going to have to go back to DJI? Also been having a problem with the the controller flight mode changing. I was using it since Christmas in mode 2. Then one time I fired it up and it as all backwards when I looked it was in mode 1. I changed it back and it was fine then last time it switched back to mode 1 and hence the carnage.
Here are the parts I can see you need based on the damage in your photo:
If you cannot reconnect the wires in the gray cable, you will also need the cable set.
robvalduga
