Would you more experienced guys recommend such a tool? I don't have a problem as far as picture shaking, but it makes sense to have the props as balanced as possible? But considering it isnt too expensive, might be a good tool.
Carbon fiber will increase flight time to 1 hour, allow the Phantom to fly 15 miles and at speeds up to 75mph.
Plus, they look cool and usually shatter rather then nick upon impact.
I think this question gets asked once a week.
Interesting.... How did you perceive the AC to be "more responsive", without any physical connection?
Mahalo to you too.....The percentage of flex degree on the CF is 6.451 % less than polymeric material props. Therefore, cavitation of the air being forced over the top of the CF blade in connection with concaved belly of the blade produces 25.804 % more velocity. Furthermore, using a speed gun provided by my brother in law, showed a speed increase 1.3 mph faster covering a distance of 75 yards. Simple math actually. No connection needed. Mahalo.
None at all, stay away!Can someone elaborate on the benefits of carbon fiber reinforced props?
Sent from my SM-G900V using PhantomPilots mobile app
they will cut your skin real nice....
Well Tcope's was on a bad day.Man, mine must be defective. I only got 12 miles and speeds at 55 mph. And ya know......... I Cant Drive............... 55!
**** where is the warning label maybe disturbing to some. California will ban it.4July 2016 and it didn't hurt till the following day. The cause was a carbon prop exploding on tip over approx 3/4 meters away, never used them since.![]()
I commented earlier that DJI CF props look identical to their OE props (except the color). I can see no evidence of CF on the surface, as we often do with CF products.Well I have both CF and stock. CF seem to be a bit more stable in flight and a bit more aggressive in shifting the air which could lead on to a whole load of benefits. I would add that CF props shatter like glass, I touched a small twig a few months back and the prop shattered in to three pieces, the P3P fell and one prop shattered on touch down, due to the the angle I could not get the motors to shut down which resulted in all sorts of problems. Luckily this all happened 3' off the deck so no real damage done. I fly commercialy and around 30 hours a week in full swing, so fairly competent.
Sent from my F3311 using PhantomPilots mobile app
I have not cut one open but from what I understand is the DJI Carbon Fiber Props are carbon fiber center with a plastic coating.I commented earlier that DJI CF props look identical to their OE props (except the color) I can see no evidence of CF on the surface, as we often do with CF products.
My question to you, since you unfortunately shredded a couple, is did you notice anything inside of them that might suggest CF?
Mine are now in my toolbox, but I'm still not willing to split one open for inspection.
Please let us know what you found.![]()
Cavitation has no relavence to the context or validity of your claims here. Where does the 6.451% claimed flex reduction come from? How do it arrive at 25+% greater velocity? 25% greater velocity of what? To provide any value to the discussion you might attempt to demonstrate the higher stiffness produces greater thrust. In doing so you will need to consider the almost certain additional current demand that will result from the prop running at lower RPM for the same thrust delivery and likley loss of efficiency.The percentage of flex degree on the CF is 6.451 % less than polymeric material props. Therefore, cavitation of the air being forced over the top of the CF blade in connection with concaved belly of the blade produces 25.804 % more velocity. Furthermore, using a speed gun provided by my brother in law, showed a speed increase 1.3 mph faster covering a distance of 75 yards. Simple math actually. No connection needed. Mahalo.
From what I understand they contain CF chopped strands that will be distributed through the whole component. They don't have the significant strength and stiffness advantages that are offered by woven material construction.I have not cut one open but from what I understand is the DJI Carbon Fiber Props are carbon fiber center with a plastic coating.
I'm surprised they aren't fuzzyFrom what I understand they contain CF chopped strands that will be distributed through the whole component. They don't have the significant strength and stiffness advantages that are offered by woven material construction.
Exactly - talking utter nonsense....Cavitation has no relevance to the context or validity of your claims here. Where does the 6.451% claimed flex reduction come from? How do it arrive at 25+% greater velocity? 25% greater velocity of what? To provide any value to the discussion you might attempt to demonstrate the higher stiffness produces greater thrust. In doing so you will need to consider the almost certain additional current demand that will result from the prop running at lower RPM for the same thrust delivery and likley loss of efficiency.
Lets assume the CF props are capable of producing greater thrust at a given RPM. All this will mean is that the flight controller will command the motors to a lower RPM. The AC will still fly within the confines of the parameters set in the firmware.
