Car Charger
That's pretty cool and I guess you could charge everything with it. Does it put much drain on your battery, do you need to run the engine?
I always do run the engine, I don't know if there's any danger of it going dead and I have no desire to find out, heh.
I use a DC to AC inverter then plug the charger shipped with the P3P. Works great.
Same here. I use a 300 watt power inverter that I plug into the cig lighter adapter in the car and use the standard Phantom charger to charge. It works fine without purchasing an after market type battery charger
I would just buy a 12 volt inverter like this
In addition to the multi charger I bought on eBay, I also got a 12 volt charger which I can use in my car or I take my emergency car jumper and just plug into the 12 volt socket. It even has an inverter built in to give me 120 volts, but I haven't tried it to see how long it takes and if it'll last
Roy, yes an inverter will work.
Don carlos
