Cannot take off?
Hi all,
When I start my Drone i always calibrate my system.
But it always says CANNOT TAKE OFF????
Pls Help what to do.
Thanks again.
Hi all,
Thanks again.
Might need bit more info,,,on latest firmware etc,,,is it new,,,possible might need stick calibration under rc settings in app,does it conect up all ok,greens lights and home point gets set ok,,,,also why calibrate ,are you prompted to,,,,could try imu calibration check,that say if needs calibration or not............will it arm and start without the app conected,,that eliminate app stopping it
Reactions: MotorCycle-Man
Are you in a restricted NFZ area? That would cause it as well. See this map: Fly Safe Map
If this is not the case, we will need more detail on the issue.
First time i have checked this at me new location,,im in between 2 airports ,but i never had any prompt to inform me,,thanks for sharing fly safe map,made myself open eyes a bit wider :)........dont be shy to reply @msnauta ,,,cant advise if dont reply
I’m thinking that the calibration wouldn’t have solved this issue. I’ll watch and see if I may be wrong.
Helen Y West
