Camera has horizon tilt after "hard landing"
I've had the P3A for 2 weeks now. I did not initially have any camera tilt problem that I've been reading about. Today, I was testing out the waypoint feature in my back yard, which is wide open 2 acres with trees at edges. It worked fine a few times until on its last waypoint mission, it went 20 feet away from where one of the waypoints was, and clipped a small tree about 15 feet up before I could figure out how to stop it from reaching that tree. It fell straight down, landed upside down on soft grass, made some kind of screaming sound for a few seconds, then stopped. It appears perfectly fine once I wiped the grass stains off of it (most of the staining was on the propellers... I guess they kept turning while it was upside down?), and it immediately flew again without any trouble.
However, now there is a camera tilt. It is visible in the image, and also visible if I place on a flat surface and turn it on. (If it is off, it just dangles however it wants to dangle.) It doesn't make it unusable, but it is annoying. I can't see any physical damage to the camera or gimbal, not even a grass stain. Nothing looks bent. I'm not sure I understand how this gimbal mechanism works, but as far as I can tell, it is on purposely deciding to move the camera to this tilted position and hold it there. If I pick up the Phantom and tilt it, the camera moves to remain "level" although in this case still tilted. If I touch it with my finger, it fights me to keep it at that position.
Some posts referenced ICU calibration. I tried that and it didn't do anything. Other posts were going on about various other features to calibrate, but I can't find any other things to calibrate other than compass. Does the UI expose these features? Suggestions?
You can try to do an IMU calibration followed immediately by a gimbal calibration.
Reactions: Porc
I'm feeling rather dumb lately, but... where would I find this gimbal calibration? I checked every page of every menu in DJI GO app that I could find. Thanks.
Here's the first video that came up in google search. It should lead you to the app screens. Good luck sir.
Reactions: Porc
D'oh! I'm convinced ninjas made the UI for this app... they somehow manage to hide features in plain sight. I should have seen that... thanks. (Now, let's see if this actually works....)
It worked! Thanks Oso.
You're welcome sir.
I agree about the screens. I have also found myself hopelessly trying to find screens that I have used numerous times.
Jesmith1016
