If you're referring to the camera tilt on the app, it's the bubble shaped icon next to the tilt adjustment on your phone/pad.darby96 said:I can't find how to control the camera movement using the transmitter attitude, did it once but can't get back![]()
Sorry, it sounds like you're not familiar with how your phantom works. The startup should be your extender, your transmitter, then your bird. Make sure the camera wifi is on and you have a sd card in the slot.darby96 said:I tried that and all went well. I turned all off and now when I go thru the routine to turn all on I get pv2 is out of range.
