camera control
Discussion in 'General Discussion' started by darby96, Oct 2, 2014.
  1. darby96
    I can't find how to control the camera movement using the transmitter attitude, did it once but can't get back ;)
  2. Fplvert
    Southern Idaho USA
    If you're referring to the camera tilt on the app, it's the bubble shaped icon next to the tilt adjustment on your phone/pad. :D
  3. darby96
    I will try that Thanks
  4. darby96
    I tried that and all went well. I turned all off and now when I go thru the routine to turn all on I get pv2 is out of range.
  5. Fplvert
    Southern Idaho USA
    Sorry, it sounds like you're not familiar with how your phantom works. The startup should be your extender, your transmitter, then your bird. Make sure the camera wifi is on and you have a sd card in the slot.
    You should read the manual and check this link. It's really informative! :D
    viewtopic.php?f=27&t=23597
  6. darby96
    Okay seems like we got the problem solved...too many wifi s around giving us false syncs. Went to a new location and wala no issues. I think one of my neighbors turned his wifi power up, just over loading the system. If this is not the cause don't know what else could be. Thanks for your help made be do alot of reading and proceedure changes.
Similar Threads - camera control Forum Date
Phantom Camera Feed Froze and Flight Controls Became Slow to Respond General Discussion Aug 10, 2017
Drone Harmony update v0.3: Phantom 3 support & full camera controls Control (Go, Litchi, etc..) Jun 27, 2017
New Phantom 4 Pro - No camera signal, No gimbol control and No SD card recognised. Urgent help Phantom 4 Pro Help Jun 5, 2017
P4P+ camera control (yaw) in 'waypoints' mode Phantom 4 Pro Help May 15, 2017
Camera control board P3P Pro/Adv Discussion Apr 19, 2017
