Yes .. It won't let me calibrate it. I believe it is showing the left stick 100% up.Is there a question there?
Great question, I am trying to find the answer to that question now.Does this need to be done after the latest firmware 1.4
DJI advises callibrating everything.Does this need to be done after the latest firmware 1.4
Dam.....too confuse.....any video around the net?
Why can`t see basic things on the manuals?
Sorry, thanks D4T_Pom!
I read somewhere you rotate the sticks 360degrees (both stick).
And the the gimbal wheel up then down.
Rotating the sticks needs to be done multiple times as well as the thumb wheel.
Doing the calibrations on the P3 should be completed and learned before a battery is ever put into the aircraft. Knowing when they need to be done and how often, is important.
Frank thank you for your input.
I personally did not know that, I even tried looking like Mordor and even before I started looking online I opened up the DJI instructions and found it to be very vague lol.
But thankfully my P3A (unfortunately no longer have the P3A) was flying fine and did me well.
Thank you once again
