CAA usage of drones, distances from buildings
Northern Hemisphere
Not sure if this is the same for the FAA, but in the UK it's said that no drone with a camera can fly nearer than 150m to a building, object etc.
Does this mean it's okay to cover over the building from a min of 150ft?
No because 150m or 150 meters would be 492 feet
Think you're conflating terms, it's 150m not ft, over or within "congested" areas (so not over at all at any height...and at least 150m away from)....and 50m within any structure (no "over" restriction...so appears 50m above would be OK), provided it's not a congested area. Exact terms are here:
Small Unmanned Aircraft (20kg or less) | Aircraft | Operations and Safety
Reactions: nickyb
Thanks. So above 50m here in the UK would be okay and within the law?
In reading the law, it appears so (not a lawyer), PROVIDED it's not a congested area (ie you're fling in a relatively wide open space and not an urban area). You'll have to research what "congested" means exactly. You need to be at least 150m away from, and not over any congested area. Otherwise, 50m distance is the rule.
Reactions: nickyb
Thanks Taz. Yes, I will read up on congested. Mainly will ne flying in fields which back onto my small village but can't resist flying over the certainly non congested street.
UK Law has some very funny loop holes.
Like if you die in the House of Commons, you have to have a state funeral.
Reactions: nickyb
Digitdrew
