By P2 just die after RC calibration
Hy guys,
I updated my P2 to 2.0 and calibrate my RC sticks. All work very strange. All sticks run between 0 and +1000 but never go to -1000. When move stick my sliders move just to right and never to left.
And now when I try to start motos my P2 just sleep.
Any suggestion to fix my problem?
ginsonic said:
Hy guys,
It won't start because the calibration is not done properly. Try recalibrating again. If that doesn't work, try rebinding the receiver.
Is not a bind problem, P2 react at sticks movements.
And I have try 10 times already to calibrate my RC but values go crazy. If i move just couple microns the stick to right go to negative values (instead of positive) and after 2-3 more microns go to +1000.
I get +1000 values for any direction I move any stick.
Same problem is reproted to any assistant I use (RC or other one).
Look like P2 get good commands when try to calibrate but become crazy after I click finish button.
Look like calibration is bugged to. When I start P2 got yellow flashes. I start calibration, dance around and get first green light, change and now get again yellow flashes.
ginsonic said:
Fixed. Look like was an RC assistant problem.
Can you expound on that? The more details you can provide, the more easily new/other members can find the answer, in case they happen to have a similar problem.
Glad you got it worked out!
Fink
Fink
Look like calibration method was changed (for me at least). Before 3.0 I could calibrate just after first click on calibration. Now need to click calibration, then next button. After these clicks calibration work well.
