I dropped the FPV on the floor, now one of the antenna sockets is broken.
I'm wondering if it's possible to replace this part? Or to solder it? ( 1 pin is also broken from the socket )
As long as the PCB tracks are no cracked - this looks like an easy fix. Check ebay for a new connector. But first check the PCB for damage. Those connectors usually hook both sides of the PCB edge, so you may need to solder both sides.
