You may be able to get live HDMI out from the RX100 II but you would need an HDMI to AV converter to connect to the video transmitter. There may be lag time so that you could not use this to fly beyond LOS. If you are using the 7th channel on your RC transmitter to tilt the camera then you would need another channel or transmitter and servo/receiver to trip the shutter for stills. That is a lot of weight to carry in addition to the RX100 which is already heavy. I don't think you can use the WiFi in the camera because it may be on the same frequency as the Phantom control. The Wifi range will also be limited.
Don't know if the RX100 II will shoot stills and video simultaneously.
One low tech method to shoot stills is to just hold the shutter button down with a rubber band or strap in continuous mode. Use a large capacity card, highest quality jpeg setting and RAW. As the buffer fills up the shot to shot speed will slow down.
You could mount a second tiny FPV camera and transmitter to fly with and to get a rough idea of what the RX100 is seeing. For video you can just start the camera before you lift off.
I'm intrigued with the idea of a second tiny FPV camera and transmitter. Can you name a brand and model? I may be able to use a larger copter with greater payload for this project.
Does the frequency used by the wifi in the RX100ii conflict with any signals used by the Mini iosd or a radio controller ? The older tramsmitters use 35Mhz I think.
(Sorry for such a basic question - not a radio expert )
Did you ever make it work? Very interested because I am currently building a fixed wing autonomous drone and want to use the Sony RX100 (with a Gremsy Pixy U gimbal) on it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
