Battery won't charge
Just got my phantom this morning. Hooked it up to the charger and it will not charge
Ideas?
Tried that notta. Just keeps one bar on
When the controller was also hooked up they seemed to be charging. But it looks like the battery was just feeding off the controller or vice versa
With just the battery plugged in nothing is happening
Can you post a video so we can see?
Really nothing to show. I plug it in and it's not charging.
When I had them both plugged in and turned on the battery they seemed to be charging. But then the battery went down instead of up.
I just went to best buy and bought a new wall cord as obviously the wiring between the controller and battery is good. Let's hope this fixes it. This is a lame problem to have
Battery can be too hot and takes awhile to kick in (30 min. cool-down). Possibly is it warm?
It was right out of the box.
Good news! A new wall side power cord fixed the issue! It's now actually charging
I guess the original cord had a defect
Sure I understand
I was really frustrated. I'm glad this was a user solvable issue
I believe the prong that connect into the converter were bad. This new wall side cord is working
Doesn't say that in my manual. Just says to connect to charge either the controller or battery
Try the original cable again.
The original cable doesn't work.
The power cable is a universal power cable, had at best buy. The charging unit works fine
wkflysaphan4
