Battery Volgate Turning Yellow
It sounds like your voltage was getting low. That makes sense at that battery level. It's more important to watch the voltage -- rather than watch the colors and percentages.
3.6 is pretty low. You want to be on the ground at 3.4.
BTW, it's not a good idea to start a flight at 46% battery. That could get you into some serious trouble -- especially around water.
That all sounds reasonable. The yellow color is alerting you of the low voltage. You should be careful flying on low batteries. When in doubt, pop in a fresh battery and keep flying safely :)
Your logs look good. The only thing unusual is you took off on a battery that was nearly depleted.
I mean your battery was so low that it was not a great idea to take off on the final launch.
