I have a P3P and a P3A. I have 3 batteries that I use between both birds. Is the battery firmware for the pro the same as it is for the advanced. If I have a battery that was used on the pro and then I use it on the advanced is that an issue?
You may want to check on this before posting. You only need to look at each firmware to see that they are completely different size files.Same for both, no issue
Sure the FW package is different for the Pro and Advance...but the battery FW that is part of each package is the same.You may want to check on this before posting. You only need to look at each firmware to see that they are completely different size files.
Each firmware is complete. That is, its the entire firmware and not just an update. So firmware for EACH Phantom is DIFFERENT.
However, why would a person download and install the correct firmware and then download and install the wrong firmware just to update the batteries? Makes no sense. But bottom line... they are _NOT_ the same.Sure the FW package is different for the Pro and Advance...but the battery FW that is part of each package is the same.
Just to clarify, the OP asked if the battery firmware is the same. Which in fact it is.However, why would a person download and install the correct firmware and then download and install the wrong firmware just to update the batteries? Makes no sense. But bottom line... they are _NOT_ the same.
