Battery - distance - 4k video
I have 3 questions please
1) Is there a battery that will give you more than 30 minutes flight time?
2) How can I extend the range beyond 500m
3) How do you set up DJI go App to shoot UHD or 4k
Sorry there are so many questions.
Beginner with Phantom 3 Standard
Thanks in advance
John
Thanks in advance
John
No battery for this ,4k,,,,,:)
No
With the standard you can't go great distances
Find a good interference-free area to get best distance and make sure you orient the antenna correctly
You need a 4K camera to shoot 4K.
The Standard doesn't have a 4K camera.
John, I don't think your P3 Standard is 4k capable.
When you first start out the DJI Go App may restrict you to a beginners' mode with distance capped. Take a good look through your settings to remove that limit.
You can maximise flight time by flying when there is little or no wind. If you haven't already done so invest in a second battery, you will find that one isn't enough
Looking to get at least another two batteries. Even in 'Non beginner mode it is limiting me to 500m distance?
Is it limiting you to exactly 500M? If so, perhaps you've enabled the "Enable Max Distance" option and it is set to a 500M distance limit. We see that here regularly since that option is so poorly labeled.
Disable the Enable Max Distance option if you do not want to set a max distance.
Reactions: JoBe
tanglefoot
