Atti back to GPS glitch?
Discussion in 'General Discussion' started by Narrator, Jan 12, 2015.
  1. Narrator
    Melbourne, Australia
    My P2V+v3 sometimes needs a bit of a kick when going back to GPS mode from Atti mode.
    Sometimes I try to get an idea of wind strength by letting it drift in Atti mode, then I switch back to GPS mode. Just occasionally, when I flip S1 back up, the Phantom continues to drift. So I toggle Atti and GPS again and it stops drifting.
    I'm not talking great distance here, the couple of times I've seen it, the Phantom was maybe 50' to 100' away and 80' to 100' high. My antenna is usually 90 degrees to the controller, with the controller tilted, which means it's usually at an optimal angle to the Phantom.
    Has anyone else noticed this?
  2. BigPig
    P2 v.2 here, but I haven't experienced this.
  3. N017RW
    Palm Beach Co.- FL
    P2-NV,
    Always 'snaps' into stability immediately when going from Atti. to GPS along with instant yellow to greed LEDs.
  4. J.James
    Upstate NY
    Could be your s1 switch starting to fail. Plug in to the naza assistant and see if flipping back and forth on the switch from atti to gps ever has a few times were you flip the switch to gps and it dont show it going in to gps mode in the naza assistant. also try wiggling the switch in gps with out flipping it to the atti position and see if you see it change at all from wiggling the switch around. Its a farly common problem for the switches they use to start going bad When they totally fail they can even just stay in atti mode or you can be flying in gps and even a slight movement of the controller can cause it to break contact and jump around between atti and gps or fail safe and atti. or even not go in to fail safe and just stay in atti which is the default if there is no contact in the switch any of the 3 contacts in the switch.
Similar Threads - Atti GPS glitch Forum Date
Professional Once again keep losing GPS ATTI mode Atti mode Phantom 3 Help Aug 8, 2017
Standard LOST RC in atti mode no gps Phantom 3 Help Aug 5, 2017
GPS _ATTI Control (Go, Litchi, etc..) Jul 24, 2017
Standard Mode changed to "GPS_Atti" Phantom 3 Help May 4, 2017
GPS/ATTI MODE General Discussion Jan 28, 2017
