Anti interference board question
Does anyone know if this board is attached with the plugs backwards will anything be damaged?
Recently purchased a P2 and the retailer installed this incorrectly. Before talking to them I want to make sure nothing is damaged
Thanxs guys
Chris
Yah I really didn't want to find out. 1 of my partners ordered everything while I was at a funeral in Europe. Really wish I was around as I could have easily assembled everything
It probably wouldn't work properly until put the right way around, but I doubt any permanent damage would be caused by it. I think the lack of posts about "frying the interference board" should give you some comfort as well.
Still glitching even after swapping plugs around.
I assume the board is there to reduce interference between the FC and the gimbal
I haven't reviewed all my video yet but from what I watched while flying waypoints through the iPad I didn't see it glitching. Maybe a problem between the Futaba and stock receiver ?
Correct on what it does. As for the Futaba, as long as you calibrated everything per the instructions, you shouldn't see an issue with it.
mauriceg
