Antenna upgrade
Hi
I saw some videos for upgrading the controller 5.8ghz antenna of the FC40, now my FC40 cannot get so high altitude. At his max range he will "come home" and auto land..
To extend the range, i want to add a 14 dbi 5.8 mushroom antenna to the controller...
Any experience? and will it improve a lot???
Thanks guys :)
The good thing about that mod is, you can try a lot of different antennas by only screwing them on.
In theory a 14 dbi antenna would be quite an improvement and a circular polarized will help distance and altitude.
That said, I have not read about anyone trying it yet.
I have not done that mod to mine but I probably will at some point.
With an omnidirectional antenna (like the stock antenna), the signal is weakest off the top of the antenna. So if you fly it high, you need to tilt the transmitter or antenna so the side of the antenna is facing the quad.
With a directional antenna, you always need to point the antenna at your quad. They have a narrower beam or whatever you want to call it. They basically focus the signal in a smaller area, which is what gives them the increased performance
Finally got round yo doing this mod
Will update after I have tested a few antennas
Used it with a tplink antenna but not pushed it to its full range, waiting on a flytrex so I can record better data, ordered a few different antennas to test as well
I'm not sure it's related or not, but from experience trying to pull in distant television signals in the UHF range (0.3-3.0 GHz range) I had best results with flat panel bow tie and yagi type antennas. The problem with these types of antennas is they are very directions (you need to have them facing the source) otherwise the reception drops off significantly.
I modified my remote so that now it can take different antennas and I'll be using the directional 11dBi Panel antenna.
Only potential problem with that, may be the constant adjustment of the antenna orientation with respect to the phantom.
scooterbuk said:
Just ordered the parts to do the mod will post up my findings
What are the parts and how is the antenna base attached to the transmitter?
TIA
BOT
DonT
