And the Quest for Smooth Video Continues.....
Looking or the Holy Grail of PID's
So, another test flight, with some less wind above my favorite rice field. If anything goes wrong, a wet but soft landing and a sure but muddy recovery ;)
Changed back to CF Vision Style Props, they are very jerky in high winds, but do ok in moderate and no wind. One T Motor (just a few flights :( ) has developed a bad sounding bearing.
Although the SimpleBGC manual states you need to increase D to decrease low frequency oscillations, which I think I have in my previous videos, I tried decreasing them.
This sort of helps. Stability is improving, but still vibes and a bit of slow oscillation, aka wobble.
Did an advanced calibration again, horizon still drifting but a bit better.
Current SimpleBGC settings:
PID:
ROLL: 30,0.35,16
PITCH 12,0.35,14
YAW 14,0.3,14
Motor Config:
ROLL: 106
PITCH 66
YAW 84
GYRO THRUST 94
Follow Yaw Deadband 6 degrees.
Balls used: 6 soft black ones, and two blue balls from my Goodluckbuy gimbal, since I tore a black soft one up, they are like chewing gum don't you think?
I janked the Phantom around a bit, this was not a lets go slow flight.
Next will be decreasing D even more I guess, add a little P?
For the people who like to see contextual videos on youtube, right click open in new window:
http://www.youtube.com/watch?v=DMlEkHw8P_M
For the people knowing a lot about forums, but less about smooth video:
[youtube]http://www.youtube.com/watch?v=DMlEkHw8P_M[/youtube]
Shot with Gopro at 60fps, video cut and saved at 30fps.
Ow, if its not in the settings, you have to buy a better quad.
Ton,
much improved vs last video, that 3 axis gimbal is smoooth...
Looking really good, especially the bits where you can clearly see the Phantom turning hard and the horizon stays level. :D
robvalduga
