Altitude/GPS
How do you change from Altitude to gps flying mode?
A warning message tells me I should change to gps mode.
I strongly suggest you read the online manual if you don't know how to do that. You should be fully aware of all the controls before flying. There's a 3 position switch on the top left corner of the remote, P is GPS mode, A is ATTI mode, and F mode is for intelligent flight modes.
Attitude does not utilize GPS. If you switched to Atti manually you can switch back to P-GPS. If you did not do this and the app is giving you a warning, it may have switched automatically, which it will do with poor GPS reception.
It's just a warning when pgps is bit weak or blocked by object it goes atti mode till gps signal strong enough to pick up again,it does this automatically or manual by switch,,atti mode will drift with wind cause no gps lock so be ready to talk the reins,,not a problem we all get it sometimes but yes as above it in the manual:),,I saw above post but post anyway,,I write to slow lol
Reactions: MotorCycle-Man
Don carlos
