Airdata - signal strength score 0 / P3A
New P3A bought January this year. I opened an account with Airdata and I checked the signal strength score.
On 99% of the flights the sig score is 0. Best I ever got was sig strength score of 4.8
Flight time Altitude Home Distance Minor SignalErrors
A 00m 30s 35.1 ft 17 m 92
B 01m 00s 35.4 ft 22 m 84
C 01m 30s 35.8 ft 22 m 82
D 02m 00s 35.8 ft 18 m 95
E 02m 30s 36.1 ft 28 m 100
F 03m 00s 31.8 ft 7 m 110
G 03m 30s 23.6 ft 7 m 105
H 04m 00s 24.6 ft 9 m 110
I 04m 30s 20.0 ft 3 m 95
J 05m 00s 35.8 ft 12 m 98
K 05m 30s 32.5 ft 10 m 95
L 06m 00s 27.6 ft 9 m 96
M 06m 30s 27.9 ft 11 m 104
N 07m 00s 27.2 ft 3 m 114
O 07m 30s 48.9 ft 37 m 113
P 08m 00s 46.9 ft 37 m 107
Q 08m 30s 60.7 ft 28 m 115
R 09m 00s 160.8 ft 23 m 114
S 09m 30s 160.8 ft 23 m 102
T 10m 00s 160.4 ft 23 m 116
U 10m 30s 161.4 ft 23 m 109
V 11m 00s 111.9 ft 38 m 116
W 11m 30s 11.5 ft 3 m 120
X 12m 00s 10.8 ft 3 m 106
Y 12m 19s 5.2 ft 1 m 63
The flights are on a beach at least 70m from any buildings.
There are no mods to the aircraft or transmitter. All flights are in an open area and I fly less than 65m horizontal distance and 200ft altitude.
The tablet I currently use is a samsung tab 2 GT-P3110 7" with a 1 ghz CPU.
Question is: is there a problem with my P3A? Is it just an anomaly with Airdata's metrics? Or slow tablet?
Any help greatly appreciated ...
Not sure... I get much higher numbers from Airdata. Actually pout if I don't get 100 score. If you could get your hands on a RF tester, you could test the output of both drone and controller to see what numbers they produce in DB. Question: You DO position stock antennas 90 degrees to aircraft right?
Yes, I realise 100 is not achievable.
I normally have the transmitter horizontal with the antennas horizontal. _='=
The last time I was out, I had the antennas at a angle. \='= Slight improvement in signal strength at 4.8
What is the typical signal score for a P3A? 50?
If I look back at my Airdata/Healthy Drones logs, I see Signal Score in range of 67 - 100, on average around 85 (and yes, 100 is achievable - I had it once, but it was by no means a far distance flight :) - Airdata UAV - Flight Data Analysis for Drones ).
I have windsurfers, but no other mods on AC and RC.
If I compare score before and after windsurfer, I can't see much difference, but usually I don't fly further than 1 km.
I think, there are too many factors in play, and because I rarely fly in the same location and w and w/o surfers, I can't judge the effectivity of wsurfers in signal score metrics.
Looks like I have a problem with my Phantom 3A then.
Has anyone got any tips, things to try, software setting etc before I contact DJI for a warranty claim?
If you tried holding the antennas straight up, then try re-linking it to controller.
Has the controller ever been dropped or bumped?
Yes, tried the antennas at an angle, 90deg, 45 deg, 0 deg etc
Controller has never been bumped or dropped.
I will try relinking the controller.
Forgot to mention, I am in the UK. Perhaps we have a reduced output here?
RC in the UK is usually at 100mW power level.
Not to the extent you say. Either the drone transmitter/antennas are bad, or the controller transmitter/antennas are bad. Possible frayed coax inside or cracked antenna wafer, or bad transmitters. But try re-linking first.
Also try this: fly the drone right in front of you, check airdata signal strength score..... When the flight was done just feet from the controller, is the score higher?
Re-linked and done 2 test flights today, signal score is 3.5
When I am stood next to the phantom the Airdata signal errors is Green 59, but when I am flying the signal errors are purple or red, about 100 errors.
Then there seems to be a issue with either the controller or drone.
RMA time.
Set image transmission to 4 Mbps and You will see the difference.
hcashmore11
