Aircraft Antennae Mod
Allentown, PA. USA
When my heading is away from Home Point I have very a good signal. As I Yaw around towards me I lose signal. I'm just wondering if there is a simple mod like rabbit ears or something that would clear up this directional problem. Or , Do the antennae's have to be tucked into the legs of the drone ? Would letting them flop around loose help ?
Are you saying that these antennas are better than the stock?
I use to have the very same issue until I did my birdside antenna mod.
Check out this thread. Birdside antenna mod version 2.0.
Reactions: RadRocket
Sorry, should have been more clear. When I mentioned the legs of the aircraft I thought it was obvious. Definitely going to get these birdside antennaes[/QUOTE]
