A little unstable flight and got atti mode while flying. Should I be worried?
Flew my replacement phantom from dji yesterday and flew it today. I have noticed that it isn't as stable as the one I bought from best buy and during my flight the Drone went into atti mode. I was out over a lake and really had no interference. Got a little nervous as it looked as if I was losing altitude. I brought it back in and landed. Should I be concerned. I will be reviewing the logs and posting them on here later.
I've had one completely random instance like this and, like you, stayed calm and brought it back. I'd flown in the same area on countless occasions and never had a problem... And have flown there many times since and not had a single issue like it. Most odd. Personally I'd stick with it for a few more flights and see if it's a repeating problem.
I've had one completely random instance like this and, like you, stayed calm and brought it back. I'd flown in the same area on countless occasions and never had a problem... And have flown there many times since and not a sidle listen like it. Most odd. Personally I'd stick with it for a few more flights and see if it's a repeating problem.
Yea I'm going to keep an eye on it. I can't say this happened to my last one but we will see if it happens again
Today I had my first flight. Mine flew very smooth. But I dont think it was quite as stable as my last one either.
I'm hoping that's the case. The wind was a little strong yesterday so that could have played a lart
I suggest you to carefully analyze the logs and check if there is any abnormal behavior anywhere. Figure out why did you loose GPS.
Check your sensor screen right before takeoff.
I will sometimes get no data from the sensors if I do not start up in the correct order of RC,AC,APP.
Also make sure there are enough sats and the GPS signal strength is good.(4 or 5 bars) If you drop to 3 bars you are in ATTI mode and
that will be a shocker if it is windy.
Rule 1 of Flight Testing: Expect things to go wrong. Plan Accordingly.
Flying over a lake just isn't one of those things I do when I'm testing things out. Remember, Murphy was an optimist.
Reactions: Sim597
here is the log from that day. can someone take a look and see what they think. I was flying today and again got something similar. Told me i had a compass error and went to atti mode, when i wasnt near anything that would cause interference. it didnt last long but still concerning.
