- Joined
- Jun 28, 2016
- Messages
- 203
- Reaction score
- 64
- Age
- 66
- Location
- Alexandria, Virginia
- Website
- fishcrow.com
This is something that most might find obvious, but it took me a while to realize what was going on. I started out doing flights only in wide open areas and using RTH with minor corrections using the right joystick. After gaining a little experience and confidence, I started using launch sites that are more restricted. On one of those landings, the drone started getting close to a tree. I pushed the left joystick forward to increase the altitude, but I got into trouble and nearly hit the tree. After the same problem arose a few more times, I finally realized what was happening. When in RTH, you can momentarily use the left joystick to slow the descent, but the drone will resume descending as soon as you release it. I have found that it's best to cancel RTH once it's overhead and bring it in manually. That way, you can stop the descent simply by releasing the joystick. Having the drone in an RTH descent in a tight landing area is a good way to get into trouble.
